ok so I have a Max sun setup in my scene and have defined Long/ lat values, for convenience is there a way to find out what the angle of sun for given time/date etc.
I need to show projected shadows angles in Autocad
Thanks,
T
Thanks,
T
Probably use a tape helper snapped to the sun and its target - it’ll give you an angle to the x axis.
doh,
of course, forgot it gave angles,
T
The control panel for the sun position also gives you the sun Azimuth and Altitude.
It will be in VRay Stage-4 2.0 SP6. The upgrade will cost almost as much as VRay itself and all the VRay materials and shaders will be separated into a different product and you’ll be charged at least $200 for them.
hahahahaha. that was a good zing!
been a lack of Zings lately… no daforce…
