Hi to all
I’m new here and with Corona I’m testing an interior I did eith Vray. I got a huge impression by this rendering engine.
The only thing I’d like to understand is how to get each frame saved one file for each rendered image calculated.
I try to explain better. I gave a sequence of frame to render, every camera position has its frame. I gave the list as i always do in vray. first to send the calculation I put 0 to during rendering autosave they keep too much space on HDD and leaved final render 1 file.
Could someone help me to understand why i get only one file with all the renders that seems overlapped?
Thanks in advance and sorry for my english
I didn’t understand all you wrote but to render a sequence as separate files for each frame (a sequence of .jpgs .tifs or whatever you want):
- set time or pass limit in “progressive rendering” tab
- in max’s “common” tab set “time segment” or “range” or whatever just to render a series of frames
- chose output file name and folder
- render
Don’t use autosave. It is used to “backup” rendered image and it will always save in .exr.
Thanks Maru
Of course I used in max common tab exactly in frames field the sequence of frames as I usually do in vray, but the lastrender.exr autosave option gaves saved in corona folder (in folder //user/appdata…) a unique file with all frames renders overlapped in it (more merged I’d say).
That’s strange I supposed that automaticallu i would get a progression of files saved. One for each frame.
I remember I did what u indicated as point 3 and I got black image renders.So i tryed the output autosave opion putting 0 files to the during render option and 1 for the n render end opion. I’ll retry the standard workflow
