http://blog.maxwellrender.com/tips/pushing-the-limits-of-realism-of-materials/
this blog post from maxwell is talking about creating a glossy coating on a material that will give a “thin film interference” look.
I think this is kind of related to “dispersion” which i know corona cannot do but is there any other way to fake this or get a similar look?
This maybe useful to you.
greetz
Lucutus
It is also easy to set up a shader like this manually: Iridescent shader - Corona 1.5.2 - Corona for 3ds Max :: User Contributions - Chaos Forum
I tried this and think I’ve matched the setup in the Maxwell article, wasn’t too sure on the mix operation, liner add seemed to be the most similar though. Very similar render times as well. Only the chair has it.
Thinfilm on the left, 255 white on the right.
Edit: I’ve just noticed that unlike the Maxwell renders, my thin film reflection is visibly darker, I guess you would also just have to increase the IOR from 1.52 to ~1.6 when using this method.
Is there a pre planned in the future to include a thinfilm in the official build ?
And the siger shders thin film? does it work?
The material screenshot above shows Siger’s ThinFilm. It’s really a great map, using it all the time.
