How to get Vray to Corona Converter?
I have a problem with the Corona converter. I have a Corona license. I cannot run the converter without installing Vray. I can’t get Vray trial version. I have a license problem when I install Vray. So I can’t get an expired trial license. What should I do? Should I buy a one month vray license and wait for it to expire? How do friends who only use corona license solve this problem?
I provided a solution. You can delete the topic, thank you.
Instead of deleting the topic, i think it would be more useful if you could tell how you did solve the issue. Someone else might have similar problem in the future and it would be helpful if they could have a working solution without having to ask for help and wait for an answer.
To run Corona converter you dont need Vray license, you only need to install the plugin and thats it.
Its the same workaround for Vray converter, you dont need Corona license, just install the plugin so 3ds Max can recognize Material/Maps DLLs and both converter will run.
Yes, I solved it as you said. Thank you. I downloaded and installed it without getting a license. I had some license problems. My Corona license was lost. I deleted and reinstalled it, etc., I solved the problem. I thought it would at least appear as an expired license on the license page. But my real mistake was trying to run it after installing vray :smiley: It messes up the licenses. The server can’t see the licenses anymore. As I said, I reinstalled it and solved the problem.
