I was asked to do a little change to a small section of an old longish animation. The old was rendered with V-Ray 5 and I’m currently working with V-Ray 6. I have gone through the camera, light and rendering settings over and over again, but can’t find any difference in those settings. Only thing has changed is V-Ray version. The renderings look quite different - it isn’t just small flash in the seam, it’s like whole new world. What do I need to do to get the V-Ray 5 looks with V-Ray 6.
Mind if you share the scene so we can troubleshoot?
Thanks,
I have signed NDA with every client I got. I can’t even share screenshots. What I’m looking for is to get - if not exactly - but somewhat similar rendering results I had, when I used V-Ray 5 with this project.
Couldn’t you just assign some of your materials to basic assets and settings that are not related to your project then send them the scene file?
is it maybe a colorspace issue?
I think it’s more like lightning issue. The biggest differences are in ambient shadows. They are much brighter than earlier.
Well, it’s impossible to pinpoint it without the scene. Numerous changes, improvements, and bug fixes could have made the difference. Check the changelog for V-Ray 6.
The suggestion is to go back to the exact versions you rendered the rest with.
Plural: it inclueds Max’s, as in recent years it changed deeply in parts that affect our outputs.
Unfortunately, there is no guarantee (nor can there be) that a newer version of V-Ray will render an old scene in the same way out of the box, or that it can be made to look identical to an older version with some tweaking.
