How to have nodes without shadows
Hallo
Ongoing from my previous discussions/question, how can I get a node to cast a shadow. Documentation (c++) does not seem to exist.
  VRayObjectProperties noShadows = renderer()->newPlugin< VRayObjectProperties>();
  noShadows.set_shadows_visibility(false);
  noShadows.setValue("nodes", billList);
Here I am trying to set list of nodes with no shadows. This does not work. Can you please provide a method of removing shadows to specific nodes (based on GeomStatic).
Anton
This is how I did it with Python:
--create VRay Object Properties plugin
obj_props = renderer.classes.VRayObjectProperties("obj_props_name")
--connect the created VRayObjectProperties plugin to the Node plugin that it needs to affect
geo = renderer.classes.Node.getInstances()
geo[1].object_properties = obj_props
--turn off shadows
obj_props.render_stats_use = True
obj_props.shadows_visibility = False
Changing parameters in the VRayObjectProperties requires a restart to take effect.
I’m guessing you can translate it to C++, if not, do say so, so I can ask a dev for help.
