One of our customers would like to borrow licenses for their render node machines and renew them automatically, so that the licenses remain available in the event of an unexpected network disconnection.
Could you please explain how to import the Borrow license file (offline.bin) generated through My Chaos using the vrlctl command line?
Not the definitive answer you’re after, but one concrete thing that might get you there faster than the doc links above: vrlctl -help (or --help, depending on your installed License Server Controller version) should list the exact borrow/import subcommand and flags for the version you actually have — worth checking directly, since CLI flag names have shifted between LSC releases before.
You don’t actually need an offline.bin to handle network issues. The license server caches licenses locally, so if the network is disrupted it automatically falls back to the cached license instead of querying the online server, your work continues uninterrupted.
On your original question: we don’t support a CLI command for loading offline.bin. Instead, generate it from my.chaos and copy it into the directory the license server checks:
