how to in A6?
Corona A6 is great…
but I would like to know how:
having in a scene different cameras with their own exposure values, white balance, contrast, clamping.
how adjust the displacement value +/- per object
how to blend a Corona light material with a Corona standard material using a mask
and…
when the RT will be enabled?
when the dispersion will be available? I don’t want to use Keyshot anymore.
regards
thanks
unfortunately is not possible to set the contrast, color balance and clamp for each camera.
for blending Corona lightmaterial and glossy-diffuse mat I can use the self illumination feature, I donno if it’s limited.
Regarding dispersion I understand that is not a simple thing to implement.
I noticed that using BDPT absorption doesn’t work.
regards
what about “guess vert” function from vray :smiley: ?
Or use Vray’s camera with Corona’s mod on top :- ) I like to use Vray camera because I love shift tool.
Shifting is AWESOME! love shifting too, just wish all my real life lenses were shift lenses now :frowning:
Shifting is very helpful, but I have to be careful everytime I use it not to overdo it :- ) Can start to look odd faster then vertical correcting if done too much.
I could use a shift lens too… not sure if there’s even is any good one for Nikon though.
