How to increase the view port texture resolution of VRayHDRImap in Legacy Direct3D mode?
(Legacy Direct3D is Display Driver.)
Thanx
Thanx
You could use the Configure Driver dialog to tweak viewport texture size and filtering. The maximal resolution is 512x512 though.
“Match Bitmap Size as Closely as Possible” option does not work?
wishes future support.
I assume that it will not work for the 3DS Max Bitmap loader too. Have you tried this?
Of course.
Resolution of VRayHDRI is clearly low.
used texture
http://www.orangesmile.com/common/img\_city\_maps/sofia-map-0.jpg
Hi Flat,
You are right, hires texture looks better in the viewport when is loaded via 3dsmax Bitmap loader. Currently the V-Ray HDRI map is limited to 512x512 like Vasil mentioned above.
I suppose that we can improve this.
We will fix this for the next service pack.
Thanks a lot for your report Flat.
All right.
Thank you.
I´m still having the same issue on 3.6… is there a way to increase texture resolution?
You can always use the bmpfilter trick https://www.youtube.com/watch?v=4L2UXfxW3tE
but, I´m using vrahdri map… how you can plug it into that?
You don’t, you just use vraybmpfilter instead. Kind of hard to know why you want better viewport resolution. Is it as a blueprint? Then this works perfectly fine.
