Hello, I fill water in a bottle, I hope the water is static statement in bottle, but after start simulation, the water constantly wave in bottle, I wait it simulate over 600 frames, it constantly in wave, hot to let it be still statement? Thanks.
What’s the initial state of the simulation? How long is your simulation? Do you use Initial fillup or pouring the liquid in the bottle? Anyway, you can try more SPF and increase the Scene Scale option a bit ![]()
Hello, George, I simulated 600 frames, then go back to the first frame, use load & start function simulate from frame 600 again, it constantly wave. I used Initial fillup not pouring the liquid into bottle, Now SPF is 6, Scene Scale is 1, I don’t know if scale the scene how many range is good,
What is the size of the simulator (grid dimension)?
Yup, just increase the Grid → Scene Scale.
Hey,
Actually it’s simulating more correctly now since there is less chaotic movement. You can also reduce the Scale and instead increase the Steps per Frame, if they are below 10.
Cheers!
