Hello
How can I load a previously saved camera path?
I can not find such a function anywhere?
greetings
Tikos
Hello
greetings
Tikos
Hey @Tikos , thanks a lot for your inquiry.
First off, since our improved video editor, which allows you to create complex camera paths (which can be saved and loaded) has been implemented with Enscape 2.2, make sure you’re up to date. Our latest release is Enscape 2.4.
Afterward (in case you were using a version of Enscape below 2.2), you should see the following two buttons in your Enscape context menu:
Just create a camera path to your liking and save it via “Save Path”. If you want to load this path again later on, just click “Load Path”.
Let me know in case you require any further help or if anything is unclear to you. ![]()
Hey @Tikos , it looks like you’ve adjusted the Enscape context menu through ArchiCAD, and some functionalities are now missing in it.
You can either just reset the menu again through ArchiCAD, or/and activate our “Enscape Toolbar”:
This will add our dedicated Enscape toolbar into ArchiCAD and you’ll be able to access every functionality without going into the other menu.
Let me know if something is unclear to you or in case you require any further help.
Thank you so much for your help - it worked :thumbup:
I do not know what happened earlier because I did not change the menu structure.
greetings
Tikos
Happy to hear that @Tikos , if you run into any further problems or in case you have any other questions about Enscape, please let me know! ![]()
I m using Enscape for tow weeks now and it looks very interesting but it has a luck in the library like cars as archicad user we need more improvement as sketchup
specially in the texture editor like grass control and bump and light as well . I hope next release would have many options.
@archidesign_1 , a dedicated ArchiCAD material editor will definitely be implemented in a future release of Enscape, but I cannot yet promise you if this feature will find its way into Enscape 2.5, our next major release. Also, what kind of improvements would you like to see regarding Enscape and ArchICAD when it comes to lights? ![]()
Finally, cars will be available in our asset library soon as well. There’ll generally a lot more models which will follow with time.
