Hi, I’m using physical sun and sky and am wondering how I can artificially lower the horizon line using V-Ray physical sun and sky? I know it wouldn’t be totally accurate, but it would really save me if I could just nudge the horizon line down a smidge so all I see is sky without the feathered gray edge at the bottom. Thanks in advance for any help.
There’s a “Horizon offset” parameter in the VRaySky node, which does exactly that.
Hi Aleksandar and thank you for your response. I thought that parameter wasn’t working then realized the issue - I think it’s because I had set up environmental fog, which was contributing to that fuzzy line in the horizon. So it was totally my error, and your response helped lead me to figuring it out. Thank you!
