How to make a interior rendering look bright?
Dear Community,
I’m pretty sure this question was asked serveral times already, but I’m really struggling with interior renderings. Some parts of the renderings are always not well lightend. If I raise the sun or doomlight, than i have this yellow/bright exposed spots.
How can I make a general soft brightend up light for the entire room? I would like to avoid to work with rectangle lights just to brighten up dark areas, it doesn’t looks smooth.
Here you can see my struggle:
the “best” i could make
if i lower the exposure, the sun and windowlight is fine, but the rest is too dark:
if i increase the exposure to make the room look bright, than the sun and domlight is burning too much
hope you guys can help.
thanks alot!!
The burn value of the color mapping options is a nice tool to catch high contrasts. You can find a burn parameter also at the frame buffer exposure controls.
(The burn option of the general options is be used for calculating the sampling, the exposure control of the frame buffer is a kind of post work only.)
lighting should look like on your last image. overexposed. put Filmic tone mapping layer on top. done.
