Hey all, I’m having an issue with the three streams on the right hand side of the attached rendering. They are not converging when they overlap. I tried using the cascade simulator and referenced each stream to the other but it still isn’t working well… Am I missing something or is it all about tweaking numbers and trial by error? Thanks!
Hey, I see you double posted the same question. Which one should I delete?
Cheers!
