Good afternoon
We have produced some images of a clients shower screens to be published - the client has said the images are a little blurry and need to be sharper ? are we missing something or is this enscape max output quality ?
Hi, you might want to check (reduce) your Bloom and Chromatic Aberration settings, those effects might contribute to a little blurry result. Other than that I personally can’t see anything wrong regarding the image quality here. Of course you can also increase the output resolution and see if that helps.
you could also try to add just a tiny amount of outlines (around 3-5%), as this will define the edges more clearly. other than that, I also think the images look quite good and sharp already ![]()
Enscape will capture images up to 8k. Check your Visual Settings / Capture tab.
thanks all for your assistance - much appreciated
