How to model this fruit bowl?
Any pointers? I ideally want a nice clean model. I would have thought nurbs might be the best but I’m losing my patience trying to get my head around it!
How about 2 hemispherical domes cut out from each other. (or just one of them with a shell modifier)
Edit poly to chamfer edges
Then stick on a bend
then some minor scale adjustments
Done
OR
make hemisperical dome and edit poly and delete some polys
shell
chamfer corners
done
Maybe, but I find it difficult to manipulate the ‘higher edges’ so that they follow the same spherical form as the rest of the bowl. Maybe I need to take a chill-pill and have another go :wink:
Watch this - Grant Warwick- Hard Surface Essentials
And then you’ll have no trouble. It’s one of the best resources going.
Yep - I found this earlier on and it is bookmarked to watch when I have some spare time.
You could spend an hour trying to model something, or an hour watching that and 5 minutes modeling it - it’s worth making the time.
yep, I’d also say polymodeling is the fastest method. even though I can imagine it can get quite frustrating if you’ve never modeled anything that way before. might be a good exercise for future models though, so I guess it’s worth both effort and time.
I don’t see whats hard about this? Sphere, trim by a spline then extrude/shell.
(Just seeing Morbids post above. He says in one sentence what takes me many :slight_smile: Do that ^ )
This model is all about getting that top edge curve to curve down but still follow the shape of a sphere.
You have two options.
1)The boolean option
2)Graphite modeling tools polydraw/draw on surface/step build option where you can use a sphere as a reference object
and build on top of to get that top edge curve. This way is the cleanest model but does require some freehand. The point is
that you are freehand modeling/conforming always to the shape of a sphere.
Try the boolean path first. Its really quick with a bit of cleanup. Start with a low res sphere. The object you will want to boolean your sphere with
looks like a the top edge of the bowl from the side view. It’s your sine wave. Clean it, squash it, shell it, taper the top edges, add edge loops to the hard edges, turbosmooth it, and done.
That’s what I thought, but to get a clean mesh is tricky.
This is a good idea.
Here you go Richard :slight_smile:
I did it as procedural as possible for easy editing :slight_smile:
bowl.zip (26 KB)
Nice one Luke, but you really shouldn’t have done that! That’s too nice. Here’s my effort if you were interested!
bugatti fruit bowl.zip (29.7 KB)
Ha! I had a stab too. Topology is too dense and not the neatest, plus I think I added to much curve to the initial profile, but in case it’s of interest :slight_smile:
TRICKY.zip (143 KB)
Hi Tricky!
Did you make the model? …otherwise I had to give it a go :wink:
The file is here if You can use it:
001.zip (35.9 KB)
Wow guys - these are great.
you have quite a few already, but here’s another one..
http://www.caribou.it/b_bowl.zip
