Hello, I need to render an animation with denoiser render elements. The renderelements are only saved in the image when I use “V-Ray raw image file” to export the sequenz. But there is no Setup or Gama override option like when using the 3ds Max Render Output.
Is there a way to acces this setup when using “V-Ray raw image file” ?
That’s because PS lacks the 16bpc *float* workflow entirely, so all it can do to preserve the range is to promote them to 32bpc (doubling memory usage for the channel, in the process.).
Even the 32bpc one is lackluster at best.
