I am trying to use the textures from the Substance Painter in V-Ray, but they come off very dark compared to what I expect.
I have spent quite some time troubleshooting this and I am at the end at this point. I think it might have something to do with 8-bit vs 16-bit or with gamma, but I can’t hit the setting that would make it how I would expect. I can boost lightning to 10-30 times the normal and it does start to look similar, but ofc all the other objects are totally overblown with light with those settings.
Did you encounter the same problem? Do you have any idea where might be the problem?
Here is the Blender + Textures:
https://drive.google.com/open?id=1zhMIO1jcy27SgAXmldMw9nESrHMiXgCm
I tried several hdri files, even the same as in Painter, I tried various light options, with point- spot- area- hemi- lights, without lights, GI on off… I set the color space in Images to linear, raw, sRGB, any combination I could think of.
I checked this:
https://support.allegorithmic.com/documentation/integrations/vray-for-3ds-max-157352261.html
and some other pages and tutorials.
Any help would be greatly appreciated.
