Hi Support! Hope you are all well and had a good weekend
… I’m currently working on a huge store build. So far I have made all shelf products grey as the animation will only focus on the point of sale installed in the stores. They have asked if we can randomise the colour on the shelf products. Is this something I can do with the randomizer? I have 4 original shelfs done (the 4 rows to the right in my screen grab). These are then instanced round the entire store. The four rows on the left is what I want to achieve but have all the clones in the store display random colours (shades) to make the store look more realistic if this makes sense? Happy to share this scene if anyone has a good approach
Have you tried Corona Multi Shader or the C4D Variation Shader?
This example is made using Corona Multi Shader loading a few different textures and Hue and Saturation random set to 25%.
Hi Lollolo,
Not yet, not sure how I would go about doing it? Also, since I have these all as clones, is there a way to make all clones do randoms? So all clones do different colour/shade difference if this makes sence?
Both (c4d Variations and Corona Multi Shader) work also with clones. So every clone will have its own color.
Only thing which can make thing a bit more complicated is, when every color/texture can be used only ones, but that’s not the case here, as far as I understand.
. Not quite sure how to approach it but will have a go in a week or so once I get to this point.
If you only need to apply different colors to different objects, that is the typical use for the Multi Shader - https://documentation.chaos.com/space/CRC4D/125276239/Corona+Multi+Shader
Here is the 3ds Max version of that article since the C4D one lacks proper descriptions for image examples (we’ll get it fixed) - https://documentation.chaos.com/space/CRMAX/124360549/Corona+Multi+Map
If you need to place different models on the shelves in a random way, this would be a job for some other tool, perhaps there is a native C4D tool that can do it.
Works a treat! Thank you both
. Gonna tune the colours a bit…
