Is there any way to completely remove all vray materials, lights and settings from a max scene?
well …cant you just delete all vray stuff ?
then switch renders.
simple
Natty
there is a converter script you can use to convert all your vray mats into standards - just put it into your /scripts directory and run it - then select the vray mat and convert it w/ the script…
here’s the script :
ftp://ftp.hdrinc.com/4OMA/4cocolas/single\_vray\_converter05.zip
I don’t know if there is a newer version cause I don’t remember where I got this one…
paul.
