hello. stupid question, but for the life of me, can’t figure it out v5-current.
to render an animation sequence, i have to use the 3ds Max Render Production button on the tool bar.
if i choose the V-ray render production on the v-ray tool bar. it renders 1 frame then stops. i’m sure it’s not the IPR button, it’s the production button.
.. guess you may only need to set a frame range in the rendersetup. And make also there sure,that “iterative” setting is turned off and is showing “production” (via the top dropdown menu)
Hi, I have reported a task for our docs team to add a bit more description about the V-Ray Tool bar’s render button. For now we will not change the button’s function and it will stay only for single frame rendering.
