How to render color alternates in render elements or CXR?
I am helping an architectural team with a project creating design visualizations. In specific metal material the team is indecisive which tone to use and I am using CoronaSelect to make 12 colors to test out.
Is there a method I can use to render one time and have all the color variations appear in some sort of CXR format or render elements?
Thank you.
No, sorry - you would have to create an animation, keyframing the selected color in the CoronaSelect, and let it render the 12 frames. You could use “render selected” though if there is a whole scene but only one object is actually changing, in case that cuts down on render times.
Thank you Tom! That’s what I did I rendered 12 times. I hope there was an easier way, like cryptomatte/render elements.
You can leave your vote for this feature in [the most wanted feature poll](https://forum.corona-renderer.com/ The most wanted feature? ). I believe it’s called “Lightmix extended to materials, textures, …” there.
