How to render in wireframe?
Is there an option or something like that in Vray to render the whole scene in wireframe mode. like maxs default render?
you can add the vray wire map to the opacity slot of your objects materials
can you explain this further elf? where do i find vray wire map? thanks!
goto your material maps, under opacity click on maps, then choose the vray wire texture from that list of maps
Thank you.
Is there a faster way to do this with a single button?
Or should I write my own script to to this to all objects in the scene?
One-button solutions are never good solutions in CG :wink:
You mean like just pressing one button to getting max started? :wink:
