This is supposed to be fixed in mid-Dec or so, i.e. you should be able to use the “-cam” flag as expected.
Not sure what build you are using, try one from late Dec and let me know if it works as expected.
Thanks!
Yeah, this is what I meant, sorry. It has been an issue for some time, so I guess I was too focused on it while reading your post.
Will check if/how that can be done with standalone.
One way to do it is to export one .vrscene with the “Separate files” option; then you can export the cameras to two other .vrscene files and replace the Render View definitions before rendering.
