How to reset preset settings to default
When I open a new model to render, it seems that I still have the settings in enscape that I used for the last project. Before the upgrade, there was an option in settings to reset all back to default. I don’t see that now…is it there somewhere?
Thanks!
@dldieterich2 , you can just right-click on any setting you like and then:
Hope that helps! :slight_smile:
In the last version,
you could just click one button to reset all defaults before a new project. Are you saying that you now need to click on every slider individually? That seems like a downgrade from the earlier version.
And adding to the above question, if I’ve created a preset, and then made a few adjustments, I also don’t see a way to just save those updates in that preset…I have to create a new preset with each incremental change?
@dldieterich2 Please make sure that you’ve opened the sidepanel of the visual settings by pressing the arrow-button.
Right-click the preset in the list. A context menu opens. There you can select “reset to default”.
The changes are saved automatically. If you have selected Preset A and you do changes to Preset A, Enscape updates it immediately. We are aware that this behavior causes some downsides which are already discussed in the forum. You can follow the discussion here.
We are collecting more insights to improve the behavior of the presets.
