How to safely shut down DR server?
I have some renders that will take a bit longer to render and some of the DR servers will be needed for working during the days.
What’s the safe way to shut down a DR server? Close the server window or rather the CMD window? Which one to close first? I guess what I’d like to know is how to make sure all rendered tiles will be transmitted to the DR master and nothing’s going to be lost?
If you know what you are doing you can close it when you like imho (drserver window). You may check the working directory for a possibly needed manual cleanup afterwards. The master will just report the slave as failed after a while. However you will not be able to let the slave rejoin until a new job arrives/a frame change occurs. Render result is sent in “Synchronization interval” (+/- a few seconds) regulary, this is the maximum render contribution which is waisted.
But I would not do it like this anyway. Have you considered to just let the dr job(s) run and work with another session with adjusted affinity/priority (also remember that you can use string options to adjust thread usage for DR slaves)? If ram is not a problem that should be ok.
Personally when having no dedicated render node available I would let the jobs crunch by backburner (as service) with idle priority/adjusted affinity in the background on one box each to get the full advantage of adaptivity (corona 1.5.2).
Good Luck
yes, that is a safe method when we need to do extra works, and I did that almost in my every works :smiley:
but eventhough the priority is changed to low, you will still feel a little bit heavier in bigger scene
I hoped a certain procedure would make sure all tiles are transferred.
Thanks for the ideas, guys, but I really need to shut down any DR activity, then logout the user and login another one to work without any background processing.
Running DrServer.exe (Running drServer as windows service - Corona for 3ds Max :: Tutorials & Guides - Chaos Forum) avoids user dependency completely and you can log on/off whomever you want even during rendering, and start/stop DrServer whenever you want without affecting the currently logged in user (if any).
But I´m sure you already know :wink:
Good Luck
