How i can to scale one instanced object /Corona proxy/ in Corona Scatter now.
Before some changing in Corona scatter system in last Corona releases it impossible via scaling basic instance model/
What’s happened Guys :(((
For polygonal onjects, you just need to add xform modifier on top of instanced object and apply transformations through it. For proxies - unfortunately, there’s no solution, appart from applying transformations directly in scatterer (on all instances), or converting proxy to mesh + xform.
Corona scatter was fixed ;]
Is at fix as bug :))) One more + for using Forest instead Corona Scatter:)))
Also scattered by path function not working as it should be, it is not place object’s on surface at the same time, like in the Forest Pack//
As now we can’t using Corona Proxy’s as scattered objects without this limitation/
very bad news:(((
Hi, i’m late to this, but yeah it will be great to have the ability to scale the proxies per element just like forest pack does..
