How to set output by vantage_console(vantage 2.0)
Hey guys,
There were output and frames options in the previous version, but they are gone now. How can I set the output through command line in vantage 2.0?
I found HTTP api is work.
import requests
import json
source_attr = {
'command': 'startLiveLinkSequence',
'path': 'c:\\1.png',
'width': '1024',
'height': '1024',
'samples': '100',
'startFrame': '1',
'endFrame': '1',
'fps': '30',
'lightCache': 'true',
'denoiser': 'true',
'pngAlpha': 'true',
'denoiserForIntermediate': '1',
'temporal': '1',
'motionBlur': '1',
'autoExposure': '1',
req_json = json.dumps(source_attr)
a = requests.post(r'http://localhost:20702/command', data=req_json)
print(a.json())
didaxr
Thank you @didaxr ,
I am not familiar with the API. Can you (or any other digital-samaritan) explain how to use that script?
Thank you very much
