is it possible with phoenix FD to create a complete cloudy sky or is there anything else recommended?
I have seen the tutorial for a single cloud, but this is maybe not suitable to build an entire sky.
My research only led to a Blender plugin, but maybe this could export then VDB to phoenix FD.
(actually I’m not familiar with blender )
Hey, there isn’t a one click solution to generating whole cloudscapes in Phoenix - there were other topics in the forum where I explained in more detail when you can use different approaches for generating single clouds, such as this approach:
… or using the Cloud toolbar preset.
And after you have generated one cloud or a set of different cloud shapes, you can instance them in the scene manually or using V-Ray instancer and render them out. Note that V-Ray instancer would require rendering in Volumetric Geometry mode.
Hope this helps get you started in the correct direction, cheers!
