How to set up DR and Backburner
Ok. 2 new computers qx6700. Cool baby…Oops had to reconfigure network. Names, IP addresses…
So now Vray slave DR rendering don’t work. Set it up again…No problems…
HOW DO I DO THAT AGAIN?
How do I actually use DR as a backburner job. What do I have to do with windows stupid firewall, why is the first thing to fall over ALWAYS vray DR. What am I doing wrong…
Is there a simple walk through somewhere so I don’t have to figure it out all over again, that takes into account the changes in Vray 1.50.00
OK
I looked up the DOCS and they’ve changed. Yipeee
and there is a walkthrough
yipeee
and I still cant get it to work.
:frowning:
this is the error message I get with max 8 on the render slaves
[2007/Oct/27|18:03:14] Extracting sequence data from RendParams.
[2007/Oct/27|18:03:14] Setting up V-Ray parameters for frame rendering.
[2007/Oct/27|18:03:14] Extracting sequence data from VRender.
[2007/Oct/27|18:03:14] Forcing multithreading
[2007/Oct/27|18:03:14] A render elements manager with 0 elements detected
[2007/Oct/27|18:03:14] Checking for missing files.
[2007/Oct/27|18:03:14] Entering beginSequence().
[2007/Oct/27|18:03:14] Setting RenderGlobalContext.
[2007/Oct/27|18:03:14] Broadcasting NOTIFY_PRE_RENDER.
[2007/Oct/27|18:03:14] error: Could not obtain a license.
[2007/Oct/27|18:03:14] Calling renderBegin().
[2007/Oct/27|18:03:14] Sending RenderBegin().
[2007/Oct/27|18:03:14] Caching camera animation.
[2007/Oct/27|18:03:14] beginSequence() done.
[2007/Oct/27|18:03:14] Entering endSequence().
[2007/Oct/27|18:03:14] Calling renderEnd().
[2007/Oct/27|18:03:14] Calling renderEnd() on render materials.
[2007/Oct/27|18:03:14] Sending RenderEnd().
[2007/Oct/27|18:03:14] Sending RenderEnd() to atmospheric effects.
[2007/Oct/27|18:03:14] Sending RenderEnd() to render effects.
[2007/Oct/27|18:03:14] Sending RenderEnd() to the tone operator.
[2007/Oct/27|18:03:14] Sending RenderEnd() to environment maps.
[2007/Oct/27|18:03:14] Unloading bitmaps.
[2007/Oct/27|18:03:14] Freeing render instances and lights.
[2007/Oct/27|18:03:14] Broadcasting NOTIFY_POST_RENDER.
[2007/Oct/27|18:03:14] endSequence() finished.
so what am i doing wrong with the licensing.
the other machine has the little dongle in it. I can see It. But for some reason the slaves don’t seem to like it I point it to the IP address of the machine with the dongle in it But still no joy.
Raj
Although I’m not an expert at DR and backburner, I do know that there is a fix for it in SP1. Whether or not it will fix your problem, I don’t know…but when it comes out in a few days, you can give it another try.
