Assuming you have your slave machines/LAN already setup, you can choose to install the DrServer when you run the A6 installation exe. I did get the following error message when I tried to open it:
If you get this message, try running the DrServer.exe as an adminstrator. Have yet to actually run anything quite yet, but I hope that helps someone out there!
You must, on the instalation of Corona, check de DR option.
Then, open on the slave computer the DrServer on: C:/Program Files (x86)/Corona/DrServer as Administrator.
On the Master computer, Enable Distribute Rendering on Corona and click Search LAN, it should find the Slave computer.
Then just Render
Where is it saying? Which door should I open?
The log just says that…
2014/02/19-16:01:08 DR server started
2014/02/19-16:01:08 Cannot read the config file, default one will be created
2014/02/19-16:01:08 Creating default DrConfig.txt: found 2 3dsmax versions
2014/02/19-16:01:08 Starting UDP socket, local hostname: amigti187.a5.local
Successfully ran some tests a couple days ago. Textures are fine if they’re stored on a network drive (and the drives are mapped the same on each machine). I take it this would slow down your render by a little (or a lot?)?
Just out of curiosity (and not having the time to test this just yet), but do you need a licensed version of Max on each machine or can it just be a demo? I noticed the slave machine opened an “unregistered” version of Max (even though it has a licensed copy installed).
I am still having problems, I couldn’t render it in DR… as my old workflow: VRAY w/ or without BACKBURNER it render fine… but with Corona it FAIL… what am I doing wrong?
For bitmap image path always check from Asset Tracking (shift + T) if everything is mapped on network drive that is from every slave machines accessible with the same drive letter.
From what i see you may have a corrupted backburner.xml file, xml tags should not show on the server window, try renaming your current backburner.xml file re enter your settings on manager settings window and backburner will create a new one.
Hi, first off all congrats and thanks to the Corona Team for a great product.
I was wondering the following i have small 3dsmax/backburner vray/drspawner renderfarm with different cpu memory configurations and i want to install corona to render instead of vray so:
Since there are diferent cpus and some don’t support SSE4.1 can the legacy version of corona coexist and work as a distribuited render node for the farm with the ones that support SSE4.1
I have 3ds max 2011 scenes worked with vray and would like to re render those with corona should i have to do some previous steps before clicking render
i render animations with backburner on a manager main pc and slave node servers, do i have to install corona’s dr server on the manager also or only on the slave nodes
Do I need to have backburner running to start rendering? I have firewall permissions, DR Server running on the slave PC, but when I click Search LAN nothing appears or if I use the slave’s IP.
