How to set up Vray GPU
I cannot find V-Ray GPU in the ActiveShade list, how can I set up V-Ray GPU?
Do you mean that you want it as a viewport? If so, then you can choose that from the viewport itself, when you click on e.g. ‘standard’ it’ll show various viewport IPR options.
I did but nothing happens, i mean the GPU not running
Is your card listed in the Perf tab like here?
Does it work in cpu mode?
Yes it is in the list.
I can run IPR in V-Ray 5 mode, but cannot run in V-Ray 5 GPU
It doesn’t work at all…not even a regular frame buffer version?
If not then that is really weird and I’m afraid I’d have no idea why that is.
Hopefully someone else can pinpoint why this happens.
Thank you for your help!
I really hope someone could help and guide me
I have no problem to run it in frame buffer, just nothing happen when i try to run it in realtime viewport, still trying here…
Do you get any messages in the V-Ray log when you start Viewport IPR with V-Ray GPU ?
Yavor
Forgot this post, The GPU works fine now…it just needs some time to start for the first time, I guess…
Ahh maybe you had the kernels compiling - it only happens on the first run and it takes more than 30 seconds.
Noted with thanks
