How to sharpen the image
Hi I’m new here and would just like to ask how do you sharpen the edges. I’ve been playing with the program and it seems that when I save it as let’s say png, the quality of the image is not that good, I get those jagged edges. Is this because I am still using the trial version or is there a setting that I need to adjust. Thanks.
I’m starting to really like the program ;D
Re: How to sharpen the image
Never had the same problem…
In which resolution are you saving you pngs?
Can you post an image so we can see?
I used viewport size which is roughly 1280x700.
This is a little embarrassing but how do I post an image? I clicked the insert image but nothing happens. Do I need to host it somewhere then just attach the link?
Thanks in advance
PNGs actually don’t have a quality setting at all. They use a form of lossless compression, which as it implies doesn’t loose any information.
JPEGs on the other end do have a quality control (which we don’t currently make accessible), and I’ve found that saving a jpeg actually results in too much smoothing, so I don’t really recommend it.
