How to show more detail in dark colors
take a look at the rendering in REVIT
the island is showing with all details in the casework
in ENSCAPE is only showing a dark volume
what setting do I have to tweak in order to get this “clear” ?
It seems you are using a pure black color, It’s advisable not to use pure blacks and pure whites as they do not exist in nature.
change the color to a dark grey and it should be fine
I Agree with @alexandrecollaco . Using SketchUp Whites have a max brightness value of 80-90 and Blacks have a min brightness value of 25-30. Also I would recommend that you need some additional lights to pull out the reflection details in the moldings of the cabinet door fronts. How are you lighting your scene?
