as in the title..
im rendering on cloud and i just want the ‘effect results’ channel to be denoised and not all the weird other elements it creates
is there a way to just render the effects result?
i ahve tried all 3 options in denoiser and they all create the extra elements
No. The created elements are necessary (it is the base data with which the denoiser calculates) to work properly.
ok thanks for the clarification.
perhaps you can add an option to not save them on render end after denoising is done then.
its not a huge issue just increases the size of files for no reason
