How to turn VRayFur "Primary Visible" OFF
Hey Guys,
call me stupid, but i haven’t found a way to change renderstats like “primary visible” or “matte Surface” on a VRayFur.
Where do i find it?
cheers
Oliver
Select the V-Ray fur preview in the viewport and then add the regular V-Ray object properties to it. You can then change the parameters of the V-Ray properties as you wish.
Another option is to adjust the “Primary visibility” option of the V-Ray fur preview node itself.
thx…i was just confused cause i thought the FurPREVIEW is just for Viewport PREVIEW :wink:
Damn! I just overlooked this…
I have a question about primary visibility.
The primary visibility always works with transparency or you will change this ?
Because obviously, with a lot of Fur (or objects), this will fail (with primary visibility with transparency).
Thank you Vlado.
Currently it works as transparency; this will change, but I cannot say when for the moment.
Because obviously, with a lot of Fur (or objects), this will fail (with primary visibility with transparency).You can increase the max. transparency levels in the V-Ray global settings to work around this.
