How to unlock Exposure Control in the Corona VFB
When you create a physical camera , press render and the image is very underexposed. However the VFB shows the exposure to be locked.
How to fix it?
1- Go to Effects and Enviroment ( or Press “8” )
2- In exposure control rollout choose “no exposure control”
Now you are free to adjust exposure from cVFB
Source: [https://forum.corona-renderer.com/ Disable Exposure Control ](https://forum.corona-renderer.com/ Disable Exposure Control )
Do not work in 3D Max 2023 and last Corona 9. Where is the exposure control in interractive rendering? Do you begin to mess arround like the all others? Did press 8 and the “exposure control” it was alreadu disabled.
This is a thread from 2019 started based on a thread from 2017. :smiley:
Are you having some specific problem? If you start interactive rendering in the VFB, you should be able to change exposure in the Post tab of the VFB.
