how can I load a video file as a texture. I tried to load a mov file….
But under the texture file windows appears a not: could not load texture file…….. Unrecognized image file format for….
Max or C4D? Which version of Corona? What are you loading the texture file into, a native bitmap, Corona bitmap, something else? General note, video depends on whether the host software has the codec to decompress it, and so the safest way to ensure compatibility is to use image sequences rather than videos. (So I guess also, what is the codec used in the video?)
Sorry just forgot to write my 3D program.
I use 3Ds Max.
But right know I found the mistake.
I used a Corona material with a Corona bitmap.
Know I tried the normal bitmap from max and it’s working with the mov file.
So problem is solved!
Will the frame rate of the video sync up to the frame rate of the scene? For instance, if the video is 1 second long and 30 fps, would you have to have at least 30 frames in order to cycle though the entire video?
Hi, just wanted to comment that I had a problem loading a video-file and/or jpg-sequence.
I was losing my mind with this and I was thinking that I have done this thing before but how on earth did I handle this before.
So the answer was: dont use CoronaBitmap - use normal Bitmap instead.
Problem solved.
Last time I used a video file for a texture I remember i could only use a mov or an avi, mp4’s didnt work. Then I used max’s bitmap rather than corona.
Mp4 normally doesn’t work and it is hard to find a non-problematic avi-codec that works for 3dsmax. Start frames get mixed up and you can’t sync video. It is best to use sequence files via a text file created from bitmap selection dialog. When you select the first frame of a sequence of frames and check Sequence in that dialog, 3DSMax creates a text file with IFL extension that contains your file names in an order. That’s the native method.
There is also a FFMPeg plugin for 3DSMax created by a Chinese guy, which worked brilliantly, But the last version I have the plugin is for 3DSMax 2018. No new versions as of my last search. MP4 Import is a real need for a 3D artist.
