How to use color correction saved curves from frame bf in render batch?
Hello!
I think the topic says everything.
I use a lot render batch but cant seem to find how to make the image save with a pre-saved color c. curve (*.bcurve) of the frame buffer customized by me. Render batch saves images in the frame buffer allways in default..
Anyone knows?
Pls :stuck_out_tongue:
Cheers
Ok. Im probably making a wrong question so ill make another noob one. :stuck_out_tongue:
Does the photoshop curve adjustment do the same job as the frame color correction curve? I mean can both do exactly the same job in the end?
If yes ill just use photoshop curve to correct the final image then.
The problem I guess is that for batch rendering, the current renderer is cloned to do the rendering - however currently V-Ray does not copy the VFB settings over to the new copy. I’ve made a note to fix this.
The photoshop curve adjustment is very similar to the one in the VFB. In fact, newer versions of the VFB can save and load curves to/from Photoshop format.
cool, didn’t know that. very handy!
