How To Use Distributed Render In Corona
I Have Three Machine In Lan But How To Use That Machines In Corona DR Render
Intall corona, an select Corona DR Server, after that go to the folder where you installed it and run DrServer.exe, after that go to your main max machine and configure the Distribute Rendering rollout, you can click “Seach LAN” or configure it manually (or load a txt with all the ip’s, one per line), and that’s it :smiley:
Cheers.
