Hello, is it possible to use the PHOENIX FD on the corona normally or do I have to do something for it to work? And if possible which version do I install?
It should just work with the latest version.
Check this out, it also mentions the versions:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000071167
Hello, I was able to use Phoenix on the corona, but I have a very difficult difficulty in generating foams and splashes, even test scenes that I have downloaded I have not been able to do, do I need to do anything other than activate them?
Ha I’m using corona 6.0 and phoenix 4.20
Could you describe more specifically what you are doing and what doesn’t seem to be working? Maybe the Phoenix knowledge base can help you get foam and splashes?
