What was the reason to use a point3 controller for the U and V offset in CoronaBitmap?
I want to wire two seperate values to the U and V offset, but both of them use a single controller. So I can’t connect up what I want, or is there another method?
For example, the following allows me to wire the Z rotation value of my sun to my HDRI: paramWire.connect $'lgt_sun.Target'.rotation.controller[#Z_Rotation] meditMaterials[24][#uvwOffset] "[-(radToDeg Z_Rotation / 360), 0, 0]"
But I also want to tilt the map in Y as well, and I can’t figure out how to do it. If the U and V values were separate single float controllers, this would be easy to do.
Not so fast though, obviously this doesn’t create a dynamic link between the two controllers, and I need to rerun the script every time the light changes, which is an issue for me, as I am simulating the rocking motion of a moving object by having the scene stationary and having the env map and sun move instead. I realise I could run a prerender script on every frame, but I was hoping there was a more elegant solution?
Ok, I figured out the syntax how to wire multiple values to control a single point3 controller: paramWire.connect $'lgt_sun.Target'.rotation.controller[#Z_Rotation] meditMaterials[24][#uvwOffset] "[$'lgt_sun.Target'.rotation.x, $'lgt_sun.Target'.rotation.y, $'lgt_sun.Target'.rotation.z]"
Finally I hook up the ‘wAngle’ in the CoronaBitmap to the appropriate axis.
Now I am having another issue with the ‘wAngle’ parameter. It looks like it displays a number in degrees, but when I give it a value in degrees, it returns some weird number and I can’t figure out why.
For example, I wire the ‘wAngle’ to my sun target like this: paramWire.connect $'lgt_sun.Target'.rotation.controller[#X_Rotation] meditMaterials[24][#wAngle] "(quatToEuler $'lgt_sun.Target'.rotation).x"
Then when I rotate my sun target 10 degrees in the x axis, the number that appears in ‘wAngle’ ends up being ‘572.958’. If I run the following, I get an output of ‘10.0’ in the Listener: (quatToEuler2 $'lgt_sun.Target'.rotation).x
Obviously there is some sort of a conversion going on, because the number I’m supplying is not the number that is output, so what type of number does ‘wAngle’ actually need?
IF your environment and sun are going to be constantly and consistently shifting back and forth (ala a boat on the ocean)… it might be easier to hook up your sun’s rotation to a waveform float controller and then hook up your hdri’s angle to a float expression controller that reads the sun’s waveform controller, that way you don’t really have to animate it by hand, and you can easily edit the waveform to meet your needs.
This might not be appropriate for what you are trying to do, but it is just a thought I had.
The orientation of the ‘world’ (sun and HDRI) is animated using a combination of noise and hand animation through a list controller on the sun target, because I have specific needs in getting the look I want for each shot. I then get the final world rotation from the target using an exposeTm object, which then drives the orientation of the HDRI.
