How vantage analysis or choose the render setting of .vrscene files
hi vantagers
title is my question, when rendering use vray5+max,there many setting parameter,such as colormaping group,they work well in max,but when I use Vantage,only gamma can work,others are invalid(all informations are right in .vrscene file). so is there a instruction to introduce how vantage work, like Supported Features per Host App,
ps: vantage doesn’t have Image modifier like vrb, I have to set render parameter to improve image, unlucky.
thank your work,best wish
Currently Vantage does not implement many separate color corrections like V-Ray does through its VFB. We will add some of them in the future. But you can transfer the color corrections from the VFB with an additional step: save all the corrections as a .LUT file (right click on Display Corrections) and load it in Vantage.
hi npg thank your reply.
at first ,your suggestion is one way;
howerver color correction is one problem, others trap me also, such as light cache ,bruteforce…
is there any plan to detail api about rendersetting , like Supported Features per Host App
Hi max_romju
Vantage doesn’t import any V-Ray specific render settings(like GI bounces, Brute force , Light cache, etc.) Can you explain more why would you need to export such quality render settings that will most probably reduce Vantage’s performance?
Alexander
Hi max_romju,
The cell size specifies the size of a single voxel, in scene units, that is used for the Light cache calculations. Low values will produce more accurate lighting but will impact performance. For additional info you can check the docs page:Chaos Vantage
Alexander
Try increasing the sample limit several times (e.g. to 1000, 2000) if you think the light cache quality is low. Better leave the other settings at their default values. Especially “filter primary rays” - leave it disabled.
Thank both of you,I will have a try
best wish
