How would one go about creating an actual carbon fiber shader?
I mean a real one - not just a lit diffuse texture and shiny-shiny. Is there a way of achieving that through shading only? If so how would you go about it? One would need the bumpyness, reacting to light the right way, aswell as a clearcoat.
you need a carbon fiber texture pattern, and matching anisotropy direction pattern, then use that as a base for your carpaint material with glossy anisotropy with ggx, and layer a reflective coat overtop.
Like Dmitry says, Anistrophy map is the technique to use combined with normal map and with clear coat on top.
Some time ago I actually did a short tutorial on carbon fiber material:
https://resources.squid.io/library-tutorials/carbon-fiber/
It is not perfect, as the shader had to conform to turbosquid guidelines, but I think is a pretty good base
Interesting information, didn’t think about the aniso technique, but it makes total sense. Thanks for the pointers!
Are those maps available somewhere to buy/download?
Here are the basic maps I used
CF_set.zip (1.64 MB)
Thanks, much appreciated.
