HSDS modifier ! FU_K
Hello Vlado,
we are working on big model with a lot of stuff not from our Studio.
I spent one day to solve a DR problem, because DR not work.
After some debug, I found in a little geometry a HSDS modifier!!!
Grrr… Argh… >=(
It’s possible that, automatically, when we use VRay as a renderer, it disable every HSDS modifier in the scene?
Until then use my good friend modifier zorb to delete/disable all of them
Yes, I will make a note to see if we can do that and print out a warning.
Thanks Vlado. Will be very useful!
R2J2 - I know this kind of script. But sometime, when you are working, you forgot to think that the problem is this modifier.
a warning is a good idea.
