I experience a huge difference in the “preview” enscape window, and exported images.
The scene is setup late night, sun is almost down. There is some lights in the building, done using emitting materials.
When I export the light get 300 % more light and the image is completely changed, and it makes it hard to get the look I search for.
What can course this difference?
The render quality is set to ultra.
Jorgensen
Hey @Jorgensen_dk , would you mind sending me a screenshot of the Enscape window side by side with the exported image? I’m yet unable to reproduce this problem with our latest release or preview.
Also, it may be helpful if you could pass me the settings which you’re currently using. You can find your saved settings here:
C:\Users<your_username>\Documents\Enscape\Settings
Thank you in advance!
Please keep things private, as it is a non public project.
We have improved that behavior, it will probably be included in the next Preview and release version. Thank you.
Thanks @Thomas_Willberger - it’s just fine now.
Jorgensen
Thank you for pointing us in the right direction(s)
the same case what i’ve posted in this forum few weeks ago..but it has been fixed already (i guess) in 2.4.097. I use 2.097 till now and it give me a good result except the reflected material also the adjustment of light value.
