Huge HD VRIMG files.
I’m wondering if there are any compression settings or methods to reduce the on-disk file size of VRIMG files? I am rendering out an animation (1080p) and need to save VRIMG files as I want to run the denoiser tool. Each frame is around 150MB.
The only render elements I have set up are the denoiser, the samplerate (I should probably get rid of this), the vrayselfillumination element and the vrayreflection.
If I can’t reduce the size, I’m going to have to bu some more hard disks :wink:
They are compressed with ZIP compression, but it’s not very effective for this type of data. You will get smaller files if you use 16-bit OpenEXR files (with or without DWAA/DWAB compression).
OK, and presumably 16-bit OpenEXRs will hold all the same info as VRIMG files?
Yes.
Just saved an exr file as instructed (well, through RPManager, I didn’t seem to have an option of 16bit) and the file is around 65MB, so I guess it contains the various matte channels and denoise info. How do I access these extra channels? Photoshop just opens it as a ‘normal’ open exr file.
(EDIT: I have EXtractoR for After Effects so I seem to be able to gain access there, but how about in Photoshop?)
