it’s similar with helicopter rotor blades. You’ve got to use a cycle as you say, but once you’ve set your up and down keyframes, you’ve got to scale them in a huge amount - you’re going in to sub frame animation where you have multiple cycles of the up and down animation withing the one frame - in 3ds max it’s called “ticks” (Minutes : Seconds : Frames : Ticks) and then you’re also going to have to use enough samples subdivisions on your motion blur to capture it. I’ve done this successfully before where I’ve done light pen animations - having a very bright object moving along the full length of a path which spells a word - you need lots of geometry samples to be able to have enough time samples to get a nice smooth arc, and then lots of subdivs to clean up the noise (or high aa).
