Husk expecting QT when previously enabled VFB experimental
if you previously enabled the VFB option “Show VFB for Husk” in the rendersettings LOP, but then disable it - it is ignored when saving out the USD for later husk rendering.
In the USD file there is still the flag set to “5” which leads to errors “No qt platform available”…
I am referring to this line in the USD file:
it is still saying:
custom int vray:vfb:show_vfb = 5
but should be after disabling:
custom int vray:vfb:show_vfb = 0
Could you look into that? Hope it was clear :wink:
Thanks and cheers
Dominik
We do not write UDS files, Solaris does it, you’ll have to figure our why it doesn’t write the correct value.
UPDATE:
Oh, ok I see, this is a fake attribute to trigger showing VFB from “Show VFB” button.
It shouldn’t be taken into account for husk for sure.​
UPDATE:
This param is not taken into account if VFB settings are not enabled. Could you pls send me the hip/usd files?
Is vray:vfb:settings_dir set?
Is vray:vfb:show_in_batch set? It’s basically the main control that enabled VFB for husk.
