After installing VRay for Houdini on MacOS Husk command line doesn’t work anymore for any render delegate.
Here is the log, it looks like it’s trying to load Qt libs for a command line app with no GUI.
[15:10:56] /Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/bin/husk version 19.5.752
[15:10:56] Command Line: /Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/bin/husk /Users/lunar/geo/untitled.usd_rop2.usd -o /Users/lunar/geo/image.png --settings /Render/rendersettings --renderer V-Ray --verbose 8
[15:10:56] CPU Apple M1 Max
[15:10:56] Architecture - AMD64: mmx sse sse2 cmov ht sse3 ssse3 sse4.1 sse4.2
[15:10:56] System limit: 10240 file descriptors
[15:10:58] Setting MATERIALX_SEARCH_PATH to '/Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/materialx'
[15:10:58] Setting PXR_MTLX_PLUGIN_SEARCH_PATHS to '/Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/materialx'
[15:10:58] Setting PXR_MTLX_STDLIB_SEARCH_PATHS to '/Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/materialx/libraries'
[15:10:58] Loading /Users/lunar/geo/untitled.usd_rop2.usd
[15:11:01] Running prerender procedurals script: /Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/husd/runprocedurals.py --mode prerender --validategeo
[15:11:01] Loading render settings: /Render/rendersettings
[15:11:01] /Render/rendersettings contains 0 render products
[2023/Oct/08|15:11:01] [info] V-Ray Hydra delegate hash:c51f859
[2023/Oct/08|15:11:01] [info] Using V-Ray Application SDK: /Applications/ChaosGroup/V-Ray/Houdini_19.5.752/appsdk
objc[66392]: Class QMacAutoReleasePoolTracker is implemented in both /Applications/Houdini/Houdini19.5.752/Frameworks/QtCore.framework/Versions/5/QtCore (0x122de2378) and /Applications/ChaosGroup/V-Ray/Houdini_19.5.752/appsdk/bin/libQt5Core.5.dylib (0x1dce93a98). One of the two will be used. Which one is undefined.
objc[66392]: Class QT_ROOT_LEVEL_POOL__THESE_OBJECTS_WILL_BE_RELEASED_WHEN_QAPP_GOES_OUT_OF_SCOPE is implemented in both /Applications/Houdini/Houdini19.5.752/Frameworks/QtCore.framework/Versions/5/QtCore (0x122de23f0) and /Applications/ChaosGroup/V-Ray/Houdini_19.5.752/appsdk/bin/libQt5Core.5.dylib (0x1dce93b10). One of the two will be used. Which one is undefined.
objc[66392]: Class KeyValueObserver is implemented in both /Applications/Houdini/Houdini19.5.752/Frameworks/QtCore.framework/Versions/5/QtCore (0x122de2418) and /Applications/ChaosGroup/V-Ray/Houdini_19.5.752/appsdk/bin/libQt5Core.5.dylib (0x1dce93b38). One of the two will be used. Which one is undefined.
objc[66392]: Class RunLoopModeTracker is implemented in both /Applications/Houdini/Houdini19.5.752/Frameworks/QtCore.framework/Versions/5/QtCore (0x122de2468) and /Applications/ChaosGroup/V-Ray/Houdini_19.5.752/appsdk/bin/libQt5Core.5.dylib (0x1dce93b88). One of the two will be used. Which one is undefined.
[B]This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.[/B]
Available platform plugins are: cocoa.
66392: (sent by pid 66392)
-- TRACEBACK BEGIN --
2 libHoudiniUT.dylib 0x0000000117c49ed7 stackTrace(UTsignalHandlerArg) + 295
3 libHoudiniUT.dylib 0x0000000117c49b07 signalCallback(UTsignalHandlerArg) + 487
4 libHoudiniUT.dylib 0x0000000118005d40 UT_Signal::processSignal(int, __siginfo*, void*) + 112
5 libsystem_platform.dylib 0x00007ff815bda37d _sigtramp + 29
6 CoreFoundation 0x00007ff85594b910 __CFURLClass + 0
7 libsystem_c.dylib 0x00007ff815acba4d abort + 126
8 QtCore 0x0000000122923179 QMessageLogger::debug(char const*, ...) const + 825
9 QtCore 0x0000000122c4435e QMessageLogger::fatal(char const*, ...) const + 196
10 QtGui 0x0000000121eeeccd QPlatformWindow::setMouseGrabEnabled(bool) + 685
11 QtGui 0x0000000121ad1fe6 QGuiApplicationPrivate::createPlatformIntegration() + 6230
12 QtGui 0x0000000121ad200b QGuiApplicationPrivate::createEventDispatcher() + 27
13 QtCore 0x0000000122aeb6ca QCoreApplicationPrivate::init() + 1146
14 QtGui 0x0000000121accb99 QGuiApplicationPrivate::init() + 57
15 QtWidgets 0x0000000120cd126a QApplicationPrivate::init() + 26
16 libvfb2_qt.so 0x00000001d25d8b46 operator delete[](void*, unsigned long) + 1607158
17 libvfb2_qt.so 0x00000001d25d8812 operator delete[](void*, unsigned long) + 1606338
18 libvray.dylib 0x00000001938351c5 VUtils::getVRayRevision() + 149
19 libVRaySDKLibrary.dylib 0x00000001ccc9bcbc VRayImage_compressToJpegFile + 3948
20 libVRaySDKLibrary.dylib 0x00000001cccf1c7a VRay_VRayRenderer_create + 42
21 vray_for_houdini.dylib 0x000000018a388f30 VRayForHoudini::VfhVRayInit::newRendererWithOptions(VRay::RendererOptions const&) + 192
22 vray_for_houdini.dylib 0x000000018a3898b3 VRayForHoudini::VfhVRayInit::initImpl(int) + 1139
23 vray_for_houdini.dylib 0x000000018a388d71 VRayForHoudini::VfhVRayInit::registerHydra(int) + 49
24 hdVRay.dylib 0x00000001caff1b5c initVRayApplicationSDK + 348
25 hdVRay.dylib 0x00000001caff32e9 pxrInternal_v0_22__pxrReserved__::HdVRayInit::init(bool) + 745
26 hdVRay.dylib 0x00000001caff2164 pxrInternal_v0_22__pxrReserved__::HdVRayRenderDelegate::createVRayRenderer() + 756
27 hdVRay.dylib 0x00000001caff3778 pxrInternal_v0_22__pxrReserved__::HdVRayRenderDelegate::HdVRayRenderDelegate(pxrInternal_v0_22__pxrReserved__::TfHashMap<pxrInternal_v0_22__pxrReserved__::TfToken, pxrInternal_v0_22__pxrReserved__::VtValue, pxrInternal_v0_22__pxrReserved__::TfToken::HashFunctor, std::__1::equal_to<pxrInternal_v0_22__pxrReserved__::TfToken>, std::__1::allocator<std::__1::pair<pxrInternal_v0_22__pxrReserved__::TfToken const, pxrInternal_v0_22__pxrReserved__::VtValue>>> const&) + 808
28 hdVRay.dylib 0x00000001cafc2a58 pxrInternal_v0_22__pxrReserved__::HdVRayRendererPlugin::createRenderDelegate(pxrInternal_v0_22__pxrReserved__::TfHashMap<pxrInternal_v0_22__pxrReserved__::TfToken, pxrInternal_v0_22__pxrReserved__::VtValue, pxrInternal_v0_22__pxrReserved__::TfToken::HashFunctor, std::__1::equal_to<pxrInternal_v0_22__pxrReserved__::TfToken>, std::__1::allocator<std::__1::pair<pxrInternal_v0_22__pxrReserved__::TfToken const, pxrInternal_v0_22__pxrReserved__::VtValue>>> const&) + 40
29 hdVRay.dylib 0x00000001cafc2c81 pxrInternal_v0_22__pxrReserved__::HdVRayRendererPlugin::CreateRenderDelegate(pxrInternal_v0_22__pxrReserved__::TfHashMap<pxrInternal_v0_22__pxrReserved__::TfToken, pxrInternal_v0_22__pxrReserved__::VtValue, pxrInternal_v0_22__pxrReserved__::TfToken::HashFunctor, std::__1::equal_to<pxrInternal_v0_22__pxrReserved__::TfToken>, std::__1::allocator<std::__1::pair<pxrInternal_v0_22__pxrReserved__::TfToken const, pxrInternal_v0_22__pxrReserved__::VtValue>>> const&) + 17
30 libpxr_hd.dylib 0x00000001498da8f0 pxrInternal_v0_22__pxrReserved__::HdRendererPlugin::CreateDelegate(pxrInternal_v0_22__pxrReserved__::TfHashMap<pxrInternal_v0_22__pxrReserved__::TfToken, pxrInternal_v0_22__pxrReserved__::VtValue, pxrInternal_v0_22__pxrReserved__::TfToken::HashFunctor, std::__1::equal_to<pxrInternal_v0_22__pxrReserved__::TfToken>, std::__1::allocator<std::__1::pair<pxrInternal_v0_22__pxrReserved__::TfToken const, pxrInternal_v0_22__pxrReserved__::VtValue>>> const&) + 64
31 libpxr_hd.dylib 0x00000001498db472 pxrInternal_v0_22__pxrReserved__::HdRendererPluginRegistry::CreateRenderDelegate(pxrInternal_v0_22__pxrReserved__::TfToken const&, pxrInternal_v0_22__pxrReserved__::TfHashMap<pxrInternal_v0_22__pxrReserved__::TfToken, pxrInternal_v0_22__pxrReserved__::VtValue, pxrInternal_v0_22__pxrReserved__::TfToken::HashFunctor, std::__1::equal_to<pxrInternal_v0_22__pxrReserved__::TfToken>, std::__1::allocator<std::__1::pair<pxrInternal_v0_22__pxrReserved__::TfToken const, pxrInternal_v0_22__pxrReserved__::VtValue>>> const&) + 66
32 libHoudiniUSD.dylib 0x0000000145400062 pxrInternal_v0_22__pxrReserved__::XUSD_HuskEngine::setRendererPlugin(pxrInternal_v0_22__pxrReserved__::XUSD_RenderSettings const&, char const*) + 1586
33 husk 0x00000001024e0a6c hdRender::render(cmdOptions&, UT_StopWatch const&) + 1932
34 husk 0x00000001025c99d7 main + 3943
35 dyld 0x00000002029953a6 start + 1942
-- TRACEBACK END --
Process finished with exit code 0
Editing this file - /Applications/Houdini/Houdini19.5.752/Frameworks/Houdini.framework/Versions/19.5/Resources/packages/vray_for_houdini.json
Removing this block allows other delegates to start rendering but removes V-Ray delegate.
{ "VFH_DSO_PATH" : [
{ "houdini_version == '19.0' and houdini_python == 'python2'": "${VFH_HOME}/dso_py2" },
{ "houdini_version == '19.0' and houdini_python == 'python3'": "${VFH_HOME}/dso_py3" },
{ "houdini_version == '19.5' and houdini_python == 'python3.7'": "${VFH_HOME}/dso_py37" },
{ "houdini_version == '19.5' and houdini_python == 'python3.9'": "${VFH_HOME}/dso_py39" },
{ "houdini_version == '20.0' and houdini_python == 'python3.10'": "${VFH_HOME}/dso_py310" }
